Discuss Hot water tank coil in the Oil and Solid Fuel Forum area at PlumbersForums.net
Can I get a backboiler connected to an indirect vented hot water cylinder through the existing small bore coil which was used previously for a pumped oil boiler, ie do I have to get a new tank with a wide bore gravity feed coil (and scrap the present hot tank?)
I understand the pump would have to be bypassed! Thank you!
Reply to Hot water tank coil in the Oil and Solid Fuel Forum area at PlumbersForums.net
We have hot water, tank for hot water why is the hot water boiling hot from tap,and shower, We are on a schedule for hot water via our hive app...
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
Sonya K
