Discuss House with gate valve as stop tap then iso valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have to do abet of work to do on a house that has lead coming in to a gate valve then an iso valve. The owner doesn't want to replace in mdpe. From boundary stop tap at the moment. So to isolate the houses water supply I have the iso valve or the boundary stop tap in the road. As the gate valve goes no were near turning off mains pressure. Which would you suggest turning of the iso valve and hope it doesn't leak out of the slotted part or the boundary stop tap. Key require to access. I will try upload a picture of under the sink its not the worlds best plumbing by any stretch of the imagination. Probably the worse layout I've seen in my limited experience.
rip out the gate valve and replace for stop tap and doc get it done right
I would but its on to lead. And the gate valve is low down. He is on about possibly getting a water meter as the water board want to fit one would they replace with mdpe from the boundary stop tap?
IMG_20160323_193121.jpg[
Theres a service valve just to the side right hand side of the tee. The pipe going to the left just feeds the kitchen sink
have you got about 4" of lead showing below the bulb? and unless you pay them for that service no as from the stop tap (main road/ sidewalk) to your inside stop tap is your problem
Would have to check when next there. Why are you thinking one of then universal transition couplings on to the lead? Would there be a possibility of connecting on to the nut and olive of the gate valve with a stop tap?
might need to cut the olive off but if you have enough copper to work with your golden
Would they fit the water meter externally then?
depends if outside already has a boss / tapping in it if no prob fit one inside but wont do that until new stop tap is fitted
The bottom nut is like an extension brass piece the? The gate valve connects on to this.
makes sense think of it like a tap connector might be tapered if it is no washer needed just jointing compound
Thanks why would this of been used though? So I maybe able to connect a stop tap to the end of this? It will either have a fibre washer or be sealed with jointing compound?
yes and if tapered jointing compound and normal back then
The pe terminating from the lead will be 1/2 brass. Cut the olive off and a 15mm one should knock on. Then fit a 15mm compression stop tap.
Thank you. I realing didn't want to start connecting on to the lead. Do you tend to use the philmac couplings now? That will go on the any material. Over lead locks?
Reply to House with gate valve as stop tap then iso valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in...
I think we have an indirect hot water cylinder, we are trying to replace a sink. However there are no isolation valves on the in-between the taps...
Hi all, I have an issue with our shower's hot water. The shower is operated using two separate taps for cold and hot water. When the hot water tap...
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution...
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
