Discuss How accurate is a hot water cylinder thermostat? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Chris123
I am looking for a way to keep a tank of fluid at an reasonably constant temperature.
How accurate are the hot water cylinder thermostats?
I'm thinking of wiring two up to to control a narrow heating range.
The field I'm heating needs to be at around 96c but if it goes over 100c it will destroy the fluid!
Thanks,
How big is the tank? And what is it for?
the main problem will keeping it all the same temp as water will be hotter at the top.
They're not accurate at all.
Sounds to me like someone's brewing hooch :)
You'll need a proper monitoring control circuit, a little bit of arduino programming should see you able to knock one up easily :) Home | OpenEnergyMonitor or JeeLabs and JeeLabs . net with a few encapsulated DS18B20 temperature sensors :) And you'll have to manage the hysteresis of the heating system as well as the monitoring system, as well as the volume and stratification of the fluid.
Simples! as Aleksandr would say.
Set up a few baffels and an ah stator and some pocket probes. Easier to control it with a bulky jacket as it won't be dynamic but very sluggish - u will need a decent pid to control lag and overshoot. Quite a tight range what size of fluid and is it exothermic or endothermic? What's the viscosity like as low viscosity more turbulent convection and better distribution . What u doing?
Note to self: ''Must go back to skool, must go bark to skool, must go bark 2 skool''
Something this close must be reaction? Any half whit would simply boil it's **** off and condense the required fraction off?
Thanks for the replies.
It's for a tank on a small anodising line. Using a nickel acetate solution. pH is 5.5 so not too bad.
Ideal temperature is 96c, but could go as low as 90.
If it boils then it destroys the anti-smut additive and parts would need to be polished after and this is time consuming.
Definitely DON'T use normal stats then nowhere near accurate enough.
You'll need a proper thermostatic control system, PT1000 sensors, and a controllable heating system - if you also use a pwm circuit to control the heating elements, you'll get much finer temperature control (as opposed to on/off) giving you exactly what you need.
Pretty standard stuff really.
Thought was trying to keep a reaction vessel at a CT on the cheap. Problem is if it's exothermic you need to cool it and endo heat it but rate of reaction can be a function of temp so it gets incredibly tetchy!
Oh I was thinking of using a distillation column or a condensing reactor to lift reagents or improve reaction. Hence boiling .
What's the weather like down under? It's raining cats and dogs up ere.
I was thinking of a meth lab.
You don't want to overheat the pseudoephidrene - particularly with the other chemicals involved.
The weather is a chilly 6C overnight and 16C during the day.
Not much rain - if any today, but the sun was shining.
Thanks,
Your average cylinder thermostat is about as crude as you can get, I never tested one but I would bet if it was plus or minus 5 Deg C I might be about right, its a crude
bimetallic strip from the 1960 and has never changed, its a bit like company car allowance 45 p miles from the 1960.
If you want to keep water in a vessel at 96 plus or minus 2 Deg C you are on the wrong website, these guys work to the nearest brick, (oh what have I said) you will also need some for of de-stratification too for the vessel, I work in process and BMS control, what is your heat source, lets have some more details, sound a bit top secret to me, or a Uni project, I
may be able to help you.
Reply to How accurate is a hot water cylinder thermostat? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
