Discuss how can i get a hot water tap in garden building with only a cold feed in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
K
karen mcavenue
hi. i am putting a loo in my garden office but only have a cold water feed. can i get hot water without using one of those triton wall mounted mini electric heaters? eg is there an electric mixer tap or something i could use instead. saw something on amazon that maybe looked ok? cheers
So you would best go with point of use ,so the would mean getting a small electric water heater fitted ,the only issue you may need an electrician to run a thicker cable ,so 2.5mm is not enough. 6mm to 10mm depending on the kws.
Reply to how can i get a hot water tap in garden building with only a cold feed in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
