Discuss How do I bend oil pipe? in the Oil and Solid Fuel Forum area at PlumbersForums.net
Jock Spanners
Evening All,
We've just moved into gas boilers (after years doing gas) and are currently tooling up. On our first install we had problems bending the 10mm plastic coated, white pipe. Possibly because of the sub-zero conditions the covering shattered when we bend it by hand. It measures 12mm (exterior diameter). I was wondering if I can buy an interior bending spring for 10mm or 12mm exterior spring. What do all you old hands use?
Many Thanks,
Jock
12mm bender but you need to heat the covering up with a hair dryer in cold temps as it breaks as you’ve found out
External
I have a rems swing set that goes from 12-32mm for my mlcp
Reply to How do I bend oil pipe? in the Oil and Solid Fuel Forum area at PlumbersForums.net
