Discuss How do I remove this tap head? Please help! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Becky DIY
This tap is dripping so I'm trying to take it apart to replace the washer but I can't work out how to get the head off the tap. Can anyone advise me please? I took the C for cold plate off expecting to find a screw head but there isn't one. There isn't a little screw on the side of the tap holding it on either. I'm wondering if there is some hard to find tool I need to fit into the sun/star shaped hole in the top or maybe it's just a turn really hard in one direction or the other job. I would really appreciate any help!
Thank you,
Becky
wrap a tea towel around it and pull straight up, mind your teeth :)
Welcome to the forum Becky, those star things are called Splines and allow the tap head to grip the spindle underneath. As said the tap head will pull straight off but you may need 2 levers under the tap head to get it moving, would suggest some towels in the basin in case the levers slip and cause damage to the basin.
Tap gently one side then the other- or change tap.
Reply to How do I remove this tap head? Please help! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need to replace the washer of my kitchen mixer tap as it is leaking. I was able to remove the spout once by unscrewing the screw on the back of...
Hi, I was hoping someone might be able to help with this. The tap is a Bristan RS BAS C, the hot tap has been leaking and I've trying to get the...
I need to change the washer on the dripping hot tap in the photo, does anybody know how to remove the dome tap handle, there's no fixings or grub...
This is probably obvious but I want to replace the cartridge to stop dripping. I have done similar before but I cannot work out how to remove the...
Hi Everyone, I hope someone might be able to help please. I hope this isn't a daft question. I am trying to remove the side panels on my...
