Discuss How do I start the heating without my thermostat (iIdeal logic combi 24 with prt2 thermostat) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Help!
I have a iIdeal logic combi 24 with prt2 thermostat.
I've broken the thermostat and now it will not communicate with the boiler.
How do I start the heating without the thermostat. The house is freezing and my pregnant wife is about to murder me.
Hi - sorry to hear about your troubles !
There are live wires inside the stat, so unless you're confident with safe isolation its dangerous to open it up.
Does he mean a 2 part stat ? Receiver/transmitter or a standard room stat
Have you got the left hand part fitted into the boiler?
Thanks for the replies.
I've managed to rebuild the thermostat and cowboy a fix on the PCB to get it transmitting again. The timer side of things is goosed though. Oh well at least we can get heat now.
Reply to How do I start the heating without my thermostat (iIdeal logic combi 24 with prt2 thermostat) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few seconds! Can anyone tell me what is causing this? And how to cure?
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
