Discuss How do I wire up this Honeywell T3R Thermostat? in the DIY Plumbing Forum area at PlumbersForums.net
Hi, I live in a really remote part of the Highlands, so paying for a plumber (or electrician?) to do this will be brutally expensive, so I need to do it myself.
I have a Grant Combi 26e boiler.
I'm replacing the old thermostat with a new one.
Although the boiler is a combi, I think the old thermostat was wired up as an on/off (it has a bridge wire)? The old system worked fine, so unless there's good reason not to, I'd like to just keep it as an on/off.
You guys probably don't need the thermostat's wiring instructions, but I've included them just in case.
In the 2nd pic I've number the new thermostat's connector things 1 to 7. Providing I don't need any more wires from the boiler, could you guys tells me which number the: "Plug Earth", "Plug Live", "Plug Neutral", "Boiler Live", and the bridge go to?
-I'm not rich at the moment, but I'll happily make a small donation to charity for the help (I see others have done this). It would be cool if the site owners had one in mind, and had a link we could use...?
Plug n to n2
Plug L to L3
L4 to a5
Boiler live to b6
Reply to How do I wire up this Honeywell T3R Thermostat? in the DIY Plumbing Forum area at PlumbersForums.net
