Discuss How fix new fill valve plastic part? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Pickles654
Hi, one of the two hooks on my toilet Torbeck fill valve has broken, and so the float can't connect. I've bought a new fill valve, however it's incredibly difficult to access underneath and replace the whole valve. I therefore just want to replace the plastic part that has the two hooks.
Annoyingly, this new part is a tiny fraction smaller and doesn't have a tiny bottom notch like the old part, which means that the new part doesn't 'click' in over the diaphragm and is a fraction loose.
It seems like I'm going to have to get a plumber in who's have to take apart some of my bathroom to get access to replace the whole valve. A fairly big job and will cost money I don't have.
Are there any fixes that I can do to make the new part work? I'm thinking superglue... or would people recommend not risking a diy job? I'm thinking the worst that would happen is it comes off and the lots of water goes down the overflow until I then replaced the valve (I can't access the toilet shut off and so am only able to repair when turning the mains isolation valve off).
Reply to How fix new fill valve plastic part? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello, I have a troublesome fixed 15mm copper pipe with isolation valve going to my toilet fill valve. It's too tight for a Flexi hose. Can I use...
Hey, I've got a leaking toilet and I need to replace the filling valve device which is a Geberit 810.L3 Type 340 with a 1/2" connector. Problem...
Hi Folks, Where is the place to order a Vaillant filling loop, please? I looked around on the net but can't seem to find it as a kit. I'm not...
Hi, I have I blend valve from Nu-Heat ( they bought it from Reliance, as per attached spec). I have dismantled the valve now 3 times and...
Hey guys in the know. I have paid for a heating and plumbing contract and had to pay my excess 3 times for the same thing still not fixed. The...
