Discuss How much extra for landlord gas safety in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Millsy 82
How much extra do I charge for a gas safety cert when I'm doing a boiler service?
I was thinking £10 extra for boiler and cert £5 per additional appliance checked?
No no no way too cheap. £20 ontop of service . But I'm yet to find a landlord who wants a service so just charge £60 for a CP12!
I thought £20 first then I thought no I'm asking too much.
Thanks for the quick reply.
It's a landlord , they need it you got it . Oh and if it fails you still did CP12 so u want ur wonga
just the same as an mot, boiler has failed, ring ring, do you want it serviced to make it pass?
I never really do landlord certs. What is the minimum you have to do on a boiler, seals, gas pressure and FGA is it?
No full 26 9 checks
Gas rate and bp tho.
Inspect pipework through it's length where visible
TT
Meter operating pressure
Earth bonding
Get a regin cp12 Ppad has most all of the checks. You can get inspection form too.
Reply to How much extra for landlord gas safety in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I’ve got a couple of gas safety checks coming up and I’m a bit confused as to whether I need to tick yes or no to the appliance serviced part...
2K
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was...
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a...
Hi, I’m having a gas cooker pipe capped off. The GS registered plumber/ fitter, has told me that to do this, he’ll also have to service the combi...
