Discuss How to change a washer in the shower in the Ireland area at PlumbersForums.net
Deleted member 117499
Hi all,
I need to change a washer on a leaking tap in my shower, but I can't figure out how to get the tap out to change it.
I can unscrew the base of the tap from the wall and get it out from the wall a little way and I can see where I would need to get a spanner/wrench onto the brass piece underneath to turn it, but I don't have a tool that can reach into the small gap and I can't see a way to actually take the tap head off as there is no screw or allen key piece in it.
Can anyone help me as to how I should go about this?
I've also attached some photos so you can see what I mean.
Thanks,
Maitreya
That head gear should come off, try looking for a grub screw in the handle (possibly where the cross head stem meets the spindle)
A lot of times the cross handle will just pull off, it can take a lot of force unfortunately.
Bad design, but it looks nicer than a grub screw apparently.
If that is a quarter turn tap, rather than a screw down one, then there will be no washer inside, but a cartridge. You would need to find an exact match for the cartridge, for which it would be much better to know the make and model of the tap. Be prepared for a shock at the price.
Reply to How to change a washer in the shower in the Ireland area at PlumbersForums.net
i can't tell if my shower tap (cock stop) is leaking or not ...............so after showering, the shower head will drip fast for 2 hours, then...
Hi All As you can see from the attached pix, the flow control knob on my Bristan shower has broken. It was installed before I bought the house...
I need to replace the washer of my kitchen mixer tap as it is leaking. I was able to remove the spout once by unscrewing the screw on the back of...
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that...
Hi. Water is slowly leaking into the toilet bowl from the cistern. I suspect that it's the rubber washer at the bottom of the tube that's the...
