Discuss How to connect to old Grey Hep20 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have this Old Grey Hep20 pipework in my bathroom and i need to reconnect to it. How do i do this? Id replace it but its all over my loft!
You would probably be safer using some inserts and copper olives and a compression joint, like the picture . However a “ modern day “ lol hep fitting should be ok . Personally I wouldn’t have any of that in my loft .
Remove what you need to back to a point don't mix fittings use the more modern white fittings and stainless inserts to make the joint to the existing grey pipe then use copper from there on .kop
Reply to How to connect to old Grey Hep20 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
  • Locked
Hi All, I am a 16 year old school leaver (Sept 23) looking for a local company to take me on as an apprentice plumber. I live in Benfleet and am...
Billy Barnard
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
