Discuss How to determine the size needed of an electric unvented water heater to supply two ensuites in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Glow worm betacom 30c combi boiler that is not connected to any water tank/cylinder in a 4 bedroom 1 bathroom house. I am adding two en-suite bathrooms which will include a shower, basin and toilet in each (saniflo systems in each). I need to identify how to determine what size unvented water heater I need to install to supply both en-suites independantly of the combi boiler as the hot water pressure is an issue. Cold water pressure is fine though. I have been advised a 50L will suffice to support two ppl showering at the same time however is this true? The new en-suites will located on the ground & first floor, and I intend to install the water heater in the kitchen on the ground floor. Below is the water heater I am looking to purchase. Will this suffice to supply enough hot water to both en-suites as well as ensure no issues with pressure (in getting the hot water to the 1st floor en-suite)
Hyco Powerflow 3KW Unvented Water Heaters | Water Heaters
Nope way off
Let's start at the beginning
What's your pressure and flow of your cold water coming in
Can test by using an outside tap or a normal tap
You might be best getting a plumber to check if you haven't got a gauge and go though the options
You will need static pressure (with no outlets open but the one with your gauge on)
Dynamic (one outlet open e.g. Kitchen sink as well as the guage on the outside tap)
And then flow rate which is easiest just time how long to fill a 1 litre container
Nope way off
Thanks for your response, I am unable to measure the flow rate right now but I believe the cold water pressure and flow rate is quite good. Once I do measure the flow rate then how do I determine what size water tank I will require for 2 ensuites?
It all depends on your pressure and flow
Can't give good advice without knowing these
12lpm give or take no way you could have more than one outlet/ shower on at the same time and really not good enough for an unvented heater / cylinder
Your only way now would be a gravity system with a pump
Unless you want to go down the road of seeing if a water main replacement could give you better flow rate
Ok thanks. What other suggestion would you advise of if the water heater was not a suitable solution and I was unable to get the water main replacement improving the flow rate?
Gravity fed hot water cylinder and 50-60 gallon plastic tank and a pump then you could run two showers at once
If you have the space
Reply to How to determine the size needed of an electric unvented water heater to supply two ensuites in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have an unvented water heater which for some reason every year causes me issues. At the end of 2023 I noticed that the pressure valve gauge was going up when the water tank was switched on. My local plumber came and re-pressured the expansion vessel as it was flat, afterwards we tested...
I have just had a boiler, hot water tank and power shower pump replaced on advice by my plumber. I have two separate boilers, heat/hotwater systems in the house. This boiler was replaced by a combi boiler as it only heats the lounge and master bed and provides hot water to en-suite bathroom and...
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the whole house is working as normal. Hot water is working as normal on the ground floor. However, there is no hot water to the first floor bathroom. This...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
Hi everyone, I have a Santon Premier Plus PP120E (unvented direct immersion heater) fitted with two thermostats, which provides hot water to taps and shower. The central heating runs from a separate system. On the PP120E: Bottom thermostat is set it to 4 out of 5 (approx. 60C), and connected...
Bridog
