Discuss How to Install Grip It Plasterboard Fixings! - Installation Notes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gripitfixings1
Grip It Fixings are a new range of plasterboard fixings on the market, designed to be able to be used on the "dot and dab" plasterboard as well as normal hollow cavity walls. Due to its slim griping wings it is able to open easily with the dab void to produce an effective secure fixing with excellent load bearing capability of up to 180kgs per fixing! excelling any cavity wall fixing currently available! - please see our website for more information!
We have had a few plumbers come back to us with a few issues on how are fixings work and how to install with ease so we thought we would put down a few installation notes:
1) When drilling the holes in the plasterboard:
- Too drill the holes for our fixings we either recommend that you use a "flat drill bit" or a "hole saw" (please use the correct size for the fixing being used) - The use of a twist drill is not recommended due to the tearing effect this produces at the back of the plasterboard, where our fixings arms need to open
2) When inserting the grip it fixings in to the plasterboard:
- Gently tap the fixing in to the plasterboard (we recommend that you insert a screw in the fixing and turn three or four times before tapping the fixing in to ensure that you will not loose the fixing behind the cavity) - Do not apply to much pressure when tapping the fixing in to the plasterboard with a hammer
- To ensure that you have tapped the fixing in at the right depth for the arms to open out, we advise that you use the depth gauge provided (on the depth gauge the 3mm protrusion is for non-plastered walls and the 6m protrusion is for plastered walls)
We recommend before inserting the Grip It Fixing you check for any obstructions that may prevent the locking arms from opening.
Like any new product, new installation methods are necessary and once mastered becomes second nature!
If anyone would like to sample our product or for more information please let us know.
Thanks,
Grip It Fixings
gripitfixings are not a forum sponsor but very kindly donated packs of there fittings to forum members for them to test out in the real world and give feed back.
there is no need to report this message as spam
I've used them on a couple of jobs now. It's a bit worrying drilling such a large hole but they held okay.
\i think i have seen some locally, they dont fill me full of confidence if truth be told
I was offered a sample but knocked them back. Too much faffing around for me.
Reply to How to Install Grip It Plasterboard Fixings! - Installation Notes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm currently refurbishing a room and in the process adding some internal wall insulation. The wall has been stripped and my plumber is coming...
3K
Hello all, Our bathroom fitters have finished the first fix. However, when the tiler came round, he pointed out these issues: Standard...
2K
We recently replaced a shower cubicle in our upstairs bathroom with a jacuzzi bath and shower cubicle and took the bath water feed from the...
J
Hi - I'm not sure if this is the right forum or not, but I'm looking for some advice with regards to a recent (nightmare) new gas boiler install...
4K
Mark Butler
M
Hi We recently moved into a property that is about 3yrs old. Ever since we have used the shower we have had a leak that is showing by the...
