PinkyPerky
Hi
I am about to plumb in a log boiler and accumulator tanks. The boiler as 2" iron flow and return and the accumulators have 11/4" connections. The Laddomat has 35mm conections. I am going to use 2" malleable iron elbows at the boiler with a malleable iron 2" to 11/4" reducer and then use 35mm copper tube throughout. The largest plumbing fittings I have used in the past were 28mm both solder and compression, and it is a long time since I used Boss White and hemp.
What would you recommend?
