Discuss How to set a timer for my hot water tank? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
I have just moved into a 2 year old flat and I'm unable to set a timer to heat my hot water. If I use the boost button on the tank then the hot water does work after around an hour, but, without pushing the boost button I don't get any hot water.
My tank is: Telford Tristor VENTED SYSTEM COMBINATION Thermal Store Copper Cylinder Supplying Mains Pressure Hot Water 150 LITRES
It also has a honeywell VC4613 attached to the tank.
On the wall in the boiler room is a micro driver fil pilote 2h - I think this is for the electric radiators in the flat though?
Any advice would be great,
Thanks.
I'm not sure what the timer is? I have no idea if it's called a honeywell or micro driver fil pilote 2h. Those are the only other 2 things in the room with the tank?
Sorry I just presumed the boost button was on a timer/programmer.
The Honeywell valve in the picture could be the culprit, there should be an adjustable thermostat on the cylinder , that you can adjust by hand / finger , just check nobody has turned it down .
The thermostat controls the Honeywell valve
My guess is if that clock is battery powered the cheap batteries have probably leaked and corroded the contacts. Even more so if the flat has been empty for a period of time.
Pfftttttt found it lol , on my phone . Moved to I pad now .
Thats for lecy rads I think
I turned the unit off because I was told that's just for the electric radiators? It turns on and works, but, we don't need the heating at the moment.
The honeywell has an adjustable movement on the side? Is that what you're talking about?
There should be a thermostat on the cylinder pal
Reply to How to set a timer for my hot water tank? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
