Discuss How to set Danfoss TP5000 temp upper limit in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have recently moved into a house with a Danfoss TP5000 remote boiler control panel.
It seems to be working just fine other than I can only go up to a max temp of 16.
The manual says there is a temperature upper limit setting but this is behind the installer advanced settings.
The manual doesn't say how to access the installer settings (understandably).
Seeing as it's just this one thing preventing it working perfectly, I was hoping I could change the setting myself.
Does anyone know how to access the installer settings for a Danfoss TP5000? Or the temperature upper limit specifically? Thanks.
Reply to How to set Danfoss TP5000 temp upper limit in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
