Discuss How to take off this Danfoss Ras-C2 TRV? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
paul10590
I know this is a danfoss ras-c2, pic attached, but how do I take it off? The reason why I want to is because it's not isolating the radiator. Have completely closed the lockshield valve but even with the TRV at 0 (past frost setting) it still lets radiator fill so I want to take TRV and check out the pin...
I've tried turning number 2 (see picture) clockwise with hand only and it doesn't budge??
There should be a little allen key bolt at the back just underneath the white head, on the bit you've labelled number 2!
are you serious an allen key to take a head off ,well you learn something new everyday lol
I can feel "something" at the back of the part labelled number 2, but that's only with my finger. It's just enough room to fit a finger, gonna be fun with an allen key :/
sorry mate I have never seen a TRV that needs an allen key to take the head off but I will bow to your superior knowledge
Yea they usually give you a really small allen key in the box when you fit. Not something that you would keep! Maybe your local merchants might be able to 'borrow' one out of a box for you if you ask them nicely. Good luck!
I just downloaded this from their site and they dont show one in the picture ,
highly accurate temperature control.
Sensor mounting requires no tools, simply press
the sensor onto the valve body and hand tighten a
clamping ring to secure.
I'm just going from memory so I may be wrong. Pretty sure there is one tho!
Just to say, you are 110% correct JonM. Had allen key set, tried various ones, 2nd to smallest worked great, came off a treat. Thankyou!!
well you maybe right but what a dumb idea how are you suppose to get to that if its tight against a wall ,get a mirror and check
Agreed gasmarc, just marked my wall all behind it doing it as turning the allen key was completely against the wall...nevermind, off now!
Reply to How to take off this Danfoss Ras-C2 TRV? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
