Discuss I need help finding toilet seat (URGENT) in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
hi, as the title suggests i need help finding this type of toilet seat, i ordered one but completely forgot to check distance between fittings and it didn't fit. The distance between the fittings for the toilet is 260mm and its for a wall hung toilet. i can't seem to find
anything similiar.
Go to a plumbers merchant and ask them to source you one. You'll pay a premium for it but the alternative is the same as anyone else, just a long slog on google trying to find one. I have absolutely no interest in doing that for nothing for you as its not at all interesting to me, I expect it will be the same for most others.
If you do go asking for help give them a drawing with dimensions;
  • distance between fixings
  • distance from fixings to the front lip
  • distance front to back of the opening
  • distance from left to right of the opening
  • distance from left to right of the entire toilet
And rotate the image because its difficult to look at upside down
Not really fb, look closer. The manufacturers name is embosed on the underside of the seat lid, otherwise no chance I would've bothered.
The seat is a non standard shape, by the time you Sod around trying to find a good or ill fitting match or bodge some fittings you might as well cough up.
You can get seats with adjustable hinges that should the fit the pan but the seat wont be a great match or go down to a merch as suggested and see that they can find for you.
You can get a generic one for about Ā£30-Ā£35 from merchants off the shelf that will fit but not match the exact shape- if youā€™re not bothered too much just do this.
i went to quite a few, they weren't able to find it
Either buy the correct one at the higher cost, or put some effort in yourself on the internet, or accept a generic square one that doesnā€™t quite fit properly.
They are your choices - this is now a boring thread!
Reply to I need help finding toilet seat (URGENT) in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
