Discuss I need to turn the water off to cold water tap in the USA area at PlumbersForums.net
Hi, I was wondering if you could help a beginner to turn off the water to my bathroom tap that needs replacing. I’ve used an isolated valve like the one on the left before and just turn it with a flat head screwdriver, but I’ve not seen the one on the right which is the one I need to turn off and looks a bit strange. Is it just the same thing but different shape Or it isn’t a valve?
Many thanks for any help you can provide.
Reply to I need to turn the water off to cold water tap in the USA area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
