Discuss ID markings on a type 1 ballcock valve in the USA area at PlumbersForums.net
Hi. looking to replace or repair a type 1 ballcock valve.
on one side embossed in the brass is BS1212 (i understand what this is)
On the other it has what appears to be KX with a frame round it embossed on the side.
Anyone shed any light on what KX is? manufacturer maybe? if so who so i can maybe get one to match
Cheers
Steve
Why does it need to match, are you not changing it?
You will get a Pt 1 from any Plumbers merchant.
Ideally I would just like to replace the "wet" half inside the cistern while leaving the other half firmly attached to the cistern and covered in paint on the outside :) or even just replace the piston. added to the fact that it looks like a well made unit as its fixing/sealing cistern nuts are brass rather than the usual white plastic these days.
I am just trying to get an idea if that KX has any relevance other than a makers mark.
I think it is a make but not sure.
Buy a pt 1 ball tap washer and replace it. Unless there is another reason to change it.
If it is a plastic piston, the washer flicks out, if it is brass they unscrew.
Reply to ID markings on a type 1 ballcock valve in the USA area at PlumbersForums.net
