Discuss Ideal Evomax w60 in ignition lockout in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi.have an issue with evomax60 ignition lockout,appliance has had new probes,gas valve and pcb 2 visits and boiler still in same fault and advise would be appreciate.
Thanks.
Jase you need to be Gas safe to get advice on Boiler repairs any advice can only be given in the private section for Gas Safe engineers and not in the public domain , if you are Gas safe registered then pm the moderators your registration details they will be checked and you will then be given access to this section of the forum . Failing that contact ideal directly for a one off repair don't allow parts to keep being swapped hoping to resolved the issue this this is false economy . Kop
What’s it doing / how far is it getting ?
Reply to Ideal Evomax w60 in ignition lockout in the Plumbing Jobs | The Job-board area at PlumbersForums.net
