Discuss Ideal icos HE18 Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
philw1ll1am
was looking for some help and advice. My Ideal HE18 boiler has failed this morning. It will fire up and 'start' working but after approx 10-20 seconds powers down again. There is no fault indication on the LED as it is flashing 'c' for the central heating. After approx 10-15 minutes the unit will attempt to power up again only to switch off again.
I've got a plumber booked for 5 tonight, but not sure I can last that long.
I hope by now that you have got this sorted, but I just thought i;d add my bit to your message in case.
I had exactly the same problem with my HE18 and luckily i had a boiler policey out at the time..Ideal service engineer came twice and claimed it was the PCB that was faulty, but despite this claim, they eventually replaced the whole boiler.
Howver, in the time i had the fault, i have learnt that there are a couple of other things that you may experience with this boiler unit, that is un-related to the PCB fault.
1. I had a lot of condensation pouring down the back of the boiler in cold weather. The fitting engineer found that when it originally was installed, they hadnt allowed enough space for the unit to 'breath' on the wall, it was a simple cure, by turning the large circular spacing disc that is visible at the bottom of the unit. Turn it until there is enough space..solved this problem
2. My Unit was making alot of banging noises, tht have become worse in this freezing spell. To stop it, was a simple case of pouring warm water over the outlet drainage pipe. It seems that these units suffer with alot of excess condensation build up when the weather gets freezing. Once the pipe is defrosted, the excess water drained away and the boiler has run fine, no noises etc..
I hope this is of some help and use.
I'm not an engineer, just passing on my experiences of this boiler so far.. hope its of some help in future to someone :)
Reply to Ideal icos HE18 Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Context for issue: Last winter the temperature switch on my boiler shorted somehow, the boiler was then running WAY too hot and ended up...
L
Hey everyone, I'll keep it short. Had our old system boiler replaced with a new Ideal system boiler set up. Then the problems began. First...
2K
Context for issue: I'd like to start by saying I'd rather not read 100 "Hire a professional comments", I will do that when/if it comes to it, but...
Butchy10
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
