Discuss Ideal icos heat only 24he power fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
king of pipes
Subscribed
Went to this boiler monday for a FL fault the condense pipe was blocked cleared that stripped it down a did a full service all ok, thursday pm phone call boiler has no power , went to have a look internal fuse ok, power in to control box and up to pcb but thats it no lights on control box anyone had this one cheers kop
was it the ones with the wires on the trap?
Is that the one where the user display plugs straight into the pcb or is it on a lead?
No shaun this one mate its probably the pcb but theres 2 one in control assembly and one primary PCB renowned for failing time to get multimeter out regards kop
Could be expensive as manufacturer advise to change both pub and user interface.
My vote new boiler :D
Thats what i feared may go reconditioned national boiler spares 1 year warranty both for £100ish thanks bud kop
Don't ideal do a fixed price repair on this of around 200 ?
Not had alot of use shaun was in a holiday home which was their second home so hardly used , now sold on so cant really push a new boiler on them looks brand new grrrr . cheers kop
Will give them a call bud .
New board £187 ooch!
Yep it's one boiler I won't repair parts are hella expensive ideal fixed price or new boiler
Went to one and phoned ideal up they fixed it ended up with nearly a new boiler new heat ex and fan and pcb (fan took the pcb out)
All for under 300 :)
Changed the main pcb and all is ok now the boilers in good condition so a few years left in it cheers for the info. Kop
Have a lot of these on my patch. Board and interface change atleast 1 a week.
Boards are tempremental, usually took out by an underlying problem.
Hopefully you've cured it tho in sorting the condensate
You home town? they are all good till they go wrong ha ha bit over the top on price for parts as shaun said the fan can take the board out but fingers crossed i wont see it for another year . kop
Nearly pal , about half way down France , tunnel booked for teatime , so hopefully back late tonight , I havnt been on this week because we have been in the middle of nowhere in Italy. Seriously those icos' s are ok , theres not a lot goes wrong with them compared to other boilers . You can pick up boards for £90 ish.
I look after a few and not as bad as people say but when the board fails and theres no indication of the fault ie some sort of fault code then can get expensive if you miss diagnose the problem hey ho its all work. Have a safe journey home mate regards kop
Reply to Ideal icos heat only 24he power fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
