Discuss ideal independent c24 F1 Fault, but pressure is high in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys, I've just spent the last half an hour going through the fourm trying ot find someone with my problem but no luck.
I have a C24 combi showing F1 fault, the pressure is high if anything - just over 2 when it should be 1.5.
Any idea how to make this error go away? I turned it off and on again whcih worked a couple of times, giving hot water, but not working anymore
Many thanks!
You can try relieving some pressure via a radiator but ultimately I think you are going to need a gas safe engineer out
Have you tried resetting the boiler eg off and on
also sometimes p/gauge sticks giving a false reading of system pressure. give the gauge a harshish tap on the front to see if it drops back.
Reply to ideal independent c24 F1 Fault, but pressure is high in the Plumbing Jobs | The Job-board area at PlumbersForums.net
