Discuss Ideal independent / classic in the Plumbing Jobs | The Job-board area at PlumbersForums.net
JAH HEATING
Does anyone on here know what the difference is with these two boilers, apart from around £200.
When ideal did this in the past with the logic/independent the warranty was 2yrs and 7 for the logic+. Badged independent for independent merchants
Classic is a 1 and independent a 2, is that all that's different the badge and warranty ?
He's wanting a Logic by sounds of it now anyhow,
Probably a marketing stragety if they're identical. I guess as long as there's no sign of the words "Isos" or "Isar"on the badge it's ok!
This job is screaming at me don't bloody do it !!!This fella is a bloody nightmare
Independant + has a 7 year and is about 70 cheaper than a logic+ for a 30kw
Reply to Ideal independent / classic in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I just installed second zone onto my ideal independent c35 original I had one hive thermostat now I added two two port valves ( with Bypass) and...
Recently noticed a gas smell coming from my ideal classic RS50 boiler. Cadent have been out and confirmed a small leak and capped off the gas. The...
Wanted old Ideal Standard Concorde Boiler for spare parts. If you are removing one please let me know. Thanks
C
I’ve had an Ideal Vogue 32max/gen2 system boiler to a Megaflo fitted a week and running it at Flow temp 73 degrees to getting a return temp of...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
