Discuss Ideal Logic+ Combi 30 - Heating but No Water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi.
Pretty much as the title describes. We have an Ideal Logic+ 30 Combi Boiler. We have heating, but we have got no water (either cold or hot) through any of the taps in the house.
The displ;ay normally shows "Winter Mode" but it is currently showing "High Efficiency Mode".
Has anybody got any ideas?
if you have no cold water i would say you have a frozen main
I don't think the main feed into the property is frozen as there is a tap that we have cold water from, before it goes into the boiler. Apologies, I should have mentioned this in the inital post.
The first tap where we have water and the boiler are both in a garage. It appears that any water that is called for after the boiler is not coming through.
Kitchen sink do you have cold water ?
so Are you getting cold water through your taps in the house? Is it just the hot that you aren’t getting?
Reply to Ideal Logic+ Combi 30 - Heating but No Water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My son has an apprenticeship interview for to become a plumber and heating engineer. The have said there will be a multiple choice exam for this...
