Discuss ideal optia boiler failing to run in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi.
I am after a bit of advice for finding the fault on my boiler system I have which I rent out. A little info about the system. It is a gravity fed system with an ideal optia he 12 boiler. It is controlled by a Danfoss 102 mechanical timer. The boiler is set to come on at 7.30am to 9 am and again at 4pm till 10pm. It come on in the morning and work fine but for some reason it doesn't come on in the evening straight away. It fires up for fifty seconds and the goes out after making a kettle type noise. It then doesn't try again for 10minutes and will go through the same sequence. On maybe its third or fourth attempt it will stay going.
It it only does this on the evening setting and not the morning one. Is it possible that the timer is faulty and not telling the pump to start and that is why it is getting the kettling effect. But if it was the timer would it start eventually?
Any help gratefully recieved. Not sure if it's worth mentioning but the hot water cylinder was emptied a couple of weeks before this started to change the kitchen taps.
cheers
Reply to ideal optia boiler failing to run in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello friends - I really struggle to understand my heating and hot water system I posted my question on Diynot but it ended up being five pages...
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any...
Hi all, The day before yesterday early morning (23rd of Jan) the temperature was very low, about -7C, so before that, I set timer to start CH for...
Ideal Logic Heat 15 System Boiler Hi. Just started to get an F3 Fan Fault on this boiler. On power up there seems to be a quiet thump from...
Deleted member 120897
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On...
