Discuss Ideal pressure for large commercial heating system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
MOSSEP
Got a heating system in a large commercial premises to look at, its had a leak and the pressure has dropped to almost nothing. There is an O&M manual for the system but it does not state what the design pressure is for it was, is it likely to be the same a domestic installs 1 - 1.5 bar or higher?
Martin
No pressurisation unit?
Check the safety valve ratings.
How many floors?
What boilers do you have?
Pressurisation unit has failed, 2 floors, not sure of boiler makes.
Can't remember the boiler manufacturer, it did state a max pressure of 6 bar in the boiler paperwork though.
Actually, theres a basement, gnd, 1st and 2nd floor so thats 4 not 2
How old is system? What's pipework like? Heat onlys chug away on 1.25 over two floors? But they arnt on "massive " systems. 600L
You're looking at 1.5bar there.
Make sure the vessel still has its charge at least.
Its a 6 year old system, hard to guage the volume to be honest. Over 150 large rads and 12 u/floor heating manifolds. Pipework is all iron and copper.
Boiler capacity in kW x 10 = volume?
Ufh floor area 0.2m3 per 100m2
Reply to Ideal pressure for large commercial heating system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
