Discuss Identifng pipe as cold water? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am pretty sure a pipe the comes out of a screed floor, (15mm with soldered cap on it) is a cold water pipe. However no way of totally chasing the pipe to see as it is not exposed. The situation is you can see two pipe drop down in the plaster of the wall. Then under the screed of the floor 2 pipes then come up out of the screed at the other side of the room to feed the washing machine, hot and cold. Half way between this a pipe comes up though the floor with a 15mm soldered cap on it. I think it is cold water it is near were a 4 inch soil pipe exits the building. The bathroom used to be in this downstairs room is now up stairs. I guess the 15mm pipe is the old cold feed to the toilet. Any way to 100% make sure? Was going to connect on to this pipe to fit an outside tap.
I through running the washer and putting a screw driver on the pipe and the other end to my ear. If I hear water running when the cold fills the washer it must be the right pipe?
Probably putting your ear to a screwdriver will work and, as you say, highly likely a single pipe is a cold pipe, as normally won't have a single hot pipe anywhere.
Is there no wiggle in the pipe to show movement at the pipe at other side?
I would just turn all water off and put a valve on the pipe to use to be able to turn valve on to check if water is on it when mains turned back on.
Or turn all waters off and cut pipe and blow through it to see what open tap water comes out off
Thanks so with all water off. If I either blow either a hot or cold tap and see when water comes out of the pipe. Or blow down the pipe and check the taps thanks. No movement in the pipe what so ever is in a solid floor screed.
All good ideas there, blow down pipe, tap with spanner etc etc.
One important thing though, never ever assume anything, ALWAYS be absolutely sure before you do anything else.
Assumption is the mother of all f##k ups.
Good advice given above. I'd just like to add, that in a property with kitchen extension etc. Don't assume stopcock under kitchen sink will isolate all mains water, especially a pipe that been capped. Make sure you can isolate in street before cutting.
You could put a temperature clamp on it as low down as possible and turn a hot tap on and se if temperature rises, then same with cold see if temperature drops.
I usually blow down the open pipe to see if water comes out a tap. Keep the other tap off that you think isn't the right one. Then you should find the pipe easy to blow down with little resistance and hopefully water coming out tap.
One fear of mine is for there to be a second mains pipe from a tee below ground before stopcock unknown to me. That happened me once when I cut into a mains pipe and I had to immediately start digging the driveway at side of a house, fortunately finding an obsolete tee off.
That's why I cut a nick in a pipe with a junior hacksaw and collect the spray of water in a container while waiting to see if flow reduces. Better than pipe slicing a live pipe off
strange no one mentioned it could be gas...
Suppose if can hear water running through while running water at the washing machine valve this would rule this out? Am I correct in saying cold water pipes usually go a darker colour then hot pipes/ gas pipes?
Cold main goes darker, if copper.
See if it was plastic that would have ruled out Gas.
Or would it?
Yes its copper. An it does appear darker. Like said it comes up next to a blanked off 4inch soil pipe so think it was the old toilet cold feed. Think the bathrom used o be down there. It is next door.
Reply to Identifng pipe as cold water? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine waste but the problem is in the water supply. Currently there is only hot and cold washing machine hose fitting isolators attached to very short...
I have decided to remove the timber floor boards and joists as they are effected by damp and rotting. Was hoping to infill and have slab and screed floor. There is a gas servile pipe under the floor which enters the property below the joists at the front of the house and comes up under the...
Morning. I have a leak. It’s coming from the connector pipe….the picture shows the pipe. It is a cold water pipe going in to the back of my dishwasher. I assume the washer may need a replacement. Anyway I cannot for the life of me turn the water off I.e at this cap. I understand I should turn...
For reasons that I won't go into. Is it possible to control the water flow to a cold water header tank without having a ballcock in the header tank? ie to place some sort of control elsewhere in the feed pipe before the water gets to the header tank - turning off the mains water supply would...
I had an outside tap fitted by a professional plumber last autumn. During the recent cold weather the feed pipe under the kitchen sink froze and the compression joint where the pipe enters an isolation valve now leaks. The outside tap was covered for the winter by an insulating blanket. I...
