Discuss Identify my Shower Valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All
This is my first post so apologies for any mistakes!
Please can someone help me identify my shower valve. The shower is leaking and I have changed the washer at the back, but it is still leaking. There is no make on the shower so cannot identify the valve. Any help will be valued! Thanks
Hi Thanks - I have sent this too them and they are trying to identify BUT looks like they are struggling too!
Sometimes it takes a couple of days. I also experienced that I had to send a reminder. So just keep asking after a couple of days.
Well, looking at your shower, it does look very similar to a tap body or 'tap reviver' from a BS5412-type tap (also known as non-rising spindle), so I would imagine it might work, and fail, in a similar way.
You could also check that the thing the washer is bolted to goes up and down properly when you turn the taphead.
Ok will check the valve mentioned. I checked and seems to go up and down smoothly?
Shower Doctor suspect it is the 'old' Crosswater style Cartridge - which is no longer available. Searched them up but no luck!
Reply to Identify my Shower Valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, Looking for some advice on my little bathroom project. I took the bath out. I got a shower jacuzzi thing. The base has 2 wheels in the corner. Do I assemble the unit first attach water and elec, and slide the very heavy unit in on the two wheels? Or do I get the base in the corner and...
