Discuss I’m a trainee gas engineer doing portfolio. in the Gas Engineers Forum area at PlumbersForums.net
For electrical thermostats to test you would establish main burner then turn on low, then burner should completely go out. Why is this?
You need to be a bit more specific, are you referring to an electric thermostat ( a dial with numbers indicated) on a boiler? If so you heat up the appliance and when the set temperature is reached, the thermostat should close the main gas valve via the solenoid.
An electronic thermostat ( thermistor) once at or close to the set temperature will modulate the main gas burner down and / or possibly switch the boiler off.
I suspect that you are refering to a Vapour Pressure FSD ( on cooker ovens). Light burner, should light on low flame, after 30 secs rises to a high flame.
Turn gas supply off, wait 90 seconds and relight - should relight on low flame
Sorry I was referring to the central heating stat, on my testing sheet it states to turn boiler stat to low once main burner has establish and should go out.
Reply to I’m a trainee gas engineer doing portfolio. in the Gas Engineers Forum area at PlumbersForums.net
Hi, I’m looking to retrain as a gas engineer and do a new entrants gas course. I’m a bit concerned by the ‘on-job’ work experience/shadowing, as...
Hi I am looking to gain practical experience with a certified gas engineer. I was in search of an engineer to work with accompanying them to...
If a gas engineer doesn't have CKR1 and has never had. How would they get it do you have to build a portfolio/ do a few days at college?
Hi everyone I currently work in oil and gas industry working in North Sea and further afield operating on high pressure oil and gas plants. This...
Just an update to anyone who was following the thread on this site: Tify to gas engineer, what will it take? I got a DM from a user asking for an...
