Discuss Imperial to metric olive - Which way? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all. I’m replacing a stop tap which is connected to black alkathene and then feeds the flat in 1/2 inch copper. I’ve bought a 22mm stopcock, along with some imperial to metric olives. These are the ones which taper on the one edge. Which way do these go? Tapered edge INTO the 22mm fitting or the other way round? Thank you.
The black pipe is the incoming mains which then reduces down to either 15mm or 1/2 inch copper. Having mulled all this over, I’m considering abandoning the replacement of the stopcock and fitting a new 15mm stopcock further along.
If you do this and you have 1/2” pipe you will need 2 x old to new connectors and some copper pipe.
I've always found them to be so close in size that the fittings are interchangeable on the 15mm - 1/2". The 22mm - 3/4" are way out so need an adapter but you have problems with the 15 to imperial?
My experience is as yours Stig.
My take on the images is top. Why? Because the longer taper is far more accommodating of dia. Look at the short end. It is perfectly matched with the olive.
Just my two penneth ;)
Reply to Imperial to metric olive - Which way? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
