Discuss Importance of full servicing in the Gas Engineers Forum area at PlumbersForums.net
king of pipes
Subscribed
I carried out a full service on a Evo today I was a bit surprised to find so much debri in the sump for some reason this one slipped through the net last year and only got a safety check won't happen again 😉
Cheers kop
Did you take the trap off underneath? They’re a bugger for getting blocked up then backs up into the sump
Yes mate I did remove the trap I cleaned it out I also flushed the heat exchanger through with water into a bowl , agreed bud it doesn't take much to block em up , do you think it's the heat exchanger being dissolved slightly by the acidic condense ? Kop
I would say it’s a possibility if the condensate pools inside the heat ex as a result of shoddy/improper servicing, as these isars/icos have always been susceptible to blockage if not serviced correctly I’ve replaced a few that have been leaking.
More likely these boiler on a monthly service contract where you pay 30quid a month just to have an fga stuck down the flue once a year, only to be told you need to stump up more cash to replace as yours is now “uneconomical to repair”
Reply to Importance of full servicing in the Gas Engineers Forum area at PlumbersForums.net
