Discuss Industrial Unit Water Boiler Reccomendation in the Commercial and Industrial Plumbing Forum area at PlumbersForums.net
Hi All, looking at getting a water boiler for our brewery and brewery taproom, we don't need central heating just need hot water for a small amount of cleaning in the brewery, bar and pizza kitchen.
Ive had a quote for supply and install (just push fit into water fittings, connect to gas) of the Ariston NEXT EVO X 16L Gas Water Heater for £950
Price wise it seems OK, the water heater looks OK on paper, but arn't Ariston sh:te;) I just wondered if anyone had any other better reccomendations?
Gas seems the best option for a new water heater as running costs are cheaper than electric medium term, so will save money in the long run purhaps, ideally want something that is easy to fix if it goes wrong and plumbers are ok to come out and fix.
Any thoughts and recommendations would be really appreciated.
How much washing up are we talking ?
How about a direct unvented cylinder?
Less to go wrong as tbh they need a lot of maintenance/ care (gas water heaters)
gledhill are a decent manufacturer
Yep or £20 you can go upto the 150l option
Sounds like a plan. Do these have a flue?
Also the heater would be around 2.5 metres up and the main flow of water would go up to the ceiling 1 metre, then along 16 metres where it goes down to the ground floor kitchen. Do you think I will need a pump or gravity will be enough for pressure. As it’s not for a shower maybe no pump required.
By direct unvented cylinder he means a mains pressure hot water cylinder directly fed (heated) by immersion heater. There is no fuel burning and hence no flue mate.
Reply to Industrial Unit Water Boiler Reccomendation in the Commercial and Industrial Plumbing Forum area at PlumbersForums.net
