Discuss Installing Wilo Circulating Pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
ApprenticeTom
I need to install a Circulating pump on the flow just under the boiler so I need to clip it but how would I space it out because the pump had a larger diameter than 22mm pipe and clips? I could just have one clip at the bottom and shorten the length of the pipe coming out the boiler valves?? Thanks any help is greatly appreciated
Reply to Installing Wilo Circulating Pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
