Discuss Insulation installation around kitchen prior to underfloor heating in the Water Underfloor Heating Advice area at PlumbersForums.net
Hi everyone.
A slight conundrum im hoping to get some educated advice on from people who actually know.
Ill be having the whole of my downstairs dug up in order to install insulation (none present) with a 75mm screed on top. Ill then have a wet system underfloor heating installed. My question is do I really need to take out the kitchen units to dig under and lay the insulation? Or can I dig around the units and then lay a type of horizontal foam divider (or something similar) to separate the uninsulated kitchen unit area from the rest of the insulated kitchen area. This im hoping with then prevent the uninsulated bit from sucking all the heat from the insulated parts?
Hope this is clear but please ask away if not.
thanks in advance.
M
Getting washing machine, dishwasher in and out after will be hard or impossible.
Just thinking this through. If you don’t remove stuff, with the insulation (typically around 70mm) and the screed, the floor will be 150mm higher than the appliances (which will now be sitting in a hole?!?!
And if your not removing the cupboards/work surfaces, the surfaces will now be 150mm lower and you’ll need to kneel to use them?!?!
Or you gonna dig down 150mm?
Getting the machines out can’t be that hard, not compared to the headache of not taking them out.
Just take it all out. You, a mate and a couple of screw guns will likely have it all out in 1/2-1 day.
Thanks everyone for your response. I appreciate the best thing to do would be to take out the kitchen units (cupboards) and granite worktop but this would be an added cost, not to mention the potential damage to them taking them out and then back in?
Sorry no mostly work in God's own county with some missionary work in surrounding areas!
Would suggest you you get underfloor heating designed by one off the major manufacturers, and get one of their registered installer's to quote for the work. You will then have a full backup warranty.
Also don't let a screening contractor kid you they can do the pipework and manifold not seen a good job yet.
Reply to Insulation installation around kitchen prior to underfloor heating in the Water Underfloor Heating Advice area at PlumbersForums.net
