Discuss Intergas rapid 25 change to system in the Central Heating Forum area at PlumbersForums.net
Inverness
Hi.
I believe this boiler can be changed to a system or combi. Does this mean the hot and cold tails have to be blanked off??
Also the horizontal flue does not come with self tappers compared to another brands I've installed in the past.. Im I right in saying it's almost like a pushfit? The elbow flue bit pushes into the boiler with out any fixings? And the horizontal flue comes with a decorative front plate how do you manage to put sand and cement in the space around the flue from the inside with this plate in the way?? I'm considering this brand of boiler but Im a bit concerned with the design.
Cheers
Yes these can be converted to any type of system in the parameter settings , flue sections are push fit only , you are not connecting a cold water supply to the boiler so I would probably add a isolation valve to the hot outlet which can be opened to check for any problems which may occur as a precaution with a push fit cap, theres a wall jig which allows piping down the back and brings the boiler forward to allow for making good of the flue regards Kop
Reply to Intergas rapid 25 change to system in the Central Heating Forum area at PlumbersForums.net
