Discuss Is a polythene membrane necessary between biscuit mix and floor boards? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi! I am looking for some feedback regarding the use of a polythene membrane between my UFH in drymix and the CaberDek floor above. We have no such thing installed, is it essential? I have only seen it suggested once as a recommendation on a website. The floor is: 200mm celotex, osb, pipes stapled to osb and buried in a sand/cement biscuit mix then topped with chip board floor boards. Any insight here would help. The supplier and fitter of our UFH both say that based o. The build up of our floor they have never used polythene membrane as suggested. Only in larger commercial builds where a concrete slab has been laid would they consider it. Your help is much appreciated! Thanks
Sorry, above isn't strictly correct, it is a vapour barrier but normally placed on top of the insulation just in the same way insulation on chilled water pipework is covered with a sealed foil outer finish which stops the passage of warm moist air passing through to condense on the cold pipe surface below.
Reply to Is a polythene membrane necessary between biscuit mix and floor boards? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
