Discuss Is it possible to have a wireless roomstat with a Baxi 105e? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Yes it is possible.
From memory they have a set of terminal blocks with 240VAC Live, Neutral and Earth with a volt free link to switch the heating. A wireless stat will also have a 240VAC live and neutral connection (unlikely to have an earth) with a set of volt free switching contacts.
Pick up your live an neutral supply from the L + N terminals on the boiler.
Remove the link on the boiler and wire it to the switching part of the stat. If you are unsure about it, don't attempt it as you can risk blowing the PCB if not connected correctly.
its the receiver for the stat you normally put it next to the boiler, some you can get wich you can swap for the time clock on certian models, it will comunicate with the stat which will be battery powerd
My fault, you wire a receiver to the boiler, the wireless stat communicates with the receiver, the receiver then turns the heating on or off.Lol, sorry i'm still confused. I don't understand how that is a wireless room stat if there's wires between the boiler and room stat. Forgive me
Reply to Is it possible to have a wireless roomstat with a Baxi 105e? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
