Discuss Is replacing a bathroom suite notifiable to bc in the Ireland area at PlumbersForums.net
If you change the position of the sanitary wear or add a none electric shower.
Any structural work to accommodate the wastes for the loo and new shower?
Think also about ventilation for the new shower, where will that run?
Cheers,
Roy
It’s a maybe then. The only change will be a bossed 40mm pipe into external soil stack. That is possibly notifiable
Does the w/c have a macerator then if only connection 40mm. Also is that 40mm under the floor? Which way do joists run.
In general there is more expertise than might first be apparent in getting wastes correct (especially as you add more stuff) do ,I'd want professional advice.
Can you include some pics and more description.
Cheers,
Roy
[automerge]1606912157[/automerge]
Does the w/c have a macerator then if the only connection is 40mm. Also is that 40mm under the floor? Which way do joists run?
In general there is more expertise than might first be apparent in getting wastes correct (especially as you add more stuff) , so I'd want professional advice.
Can you include some pics and more description perhaps.
Cheers,
Roy
Cheers,
Roy
Will do thank you. It’s not so much doing the work but if I need bc approval to do it.
Reply to Is replacing a bathroom suite notifiable to bc in the Ireland area at PlumbersForums.net
Home owner looking for some advice pls. We have a megaflow system which we are considering removing as the tank takes up a lot of space and we...
Hi All, I have a 2m x 2m bathroom suite which I'd like to completely change out myself. I'd be replacing the bathroom suite for like for like...
Hi People, So, I'm looking to fit a new Monarch Midi HE water softener, upstairs bathroom suite, downstairs WC suite and probably replace the...
I need a quote to replace a soil stack ( cast ) in Leyton e10. The stack is already in plastic at the bottom. There also needs to be amendment to...
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
