Discuss Is this condensate pump noise normal? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dnw
First post, please be gentle :cheesy:
Would forum members kindly advise whether this noise from a condensate pump (recorded at close proximity through a plasterboard casing) is normal: https://drive.google.com/open?id=0BxzNgjynKeqAZEtCbXd6aE5KT2s
Context- moved into a new flat with three comfort cooling units (FCU fed by a chilled water system). All good for 3 months and now they are making this noise when the condensate pumps run to clear the drip trays. I'm told it is 'normal' - I don't agree.
With the system running I hear three noises: 1) the noise of the fans in the FCU which run at varying rates until the desired temperature is achieved (barely audible and acceptable), 2) a buzzing noise when the condensate pump runs (sounds a bit like an electrical sub station, very quiet and well insulated, you can hear it in the background in the audio clip - again acceptable) and 3) also when the pumps run, the knocking noise in the linked audio clip (drives me up the wall when in the lounge and wakes me up at night in the bedroom - not acceptable).
The condensate pumps also seem to be overused - the one in the bedroom now runs pretty much non stop, the lounge comes on for about 30 seconds every 5 minutes or so at certain times of day. Both seem way too frequent.
Would appreciate advice on whether I'm being over-sensitive before I escalate the problem further with the developer. Their contractor changed a float switch in the bedroom and now is reluctant to return (saying the noise is normal) and has passed complaint on to the manufacturer.
Last call for help - does this noise sound like siphoning or acceptable normal operation?
I would say no, and shouldn't run all the time just when the float switch calls for it
Shouldnt run for that long and sounds off, get an engineer in to have a look
Its a condensate pump which reacts on the water level in the tank so either your boiler is producing too much water or the pump is stuck on.
I agree with gasman, i would get a engineer to take a look at that, hopefully he can truly fix the problem and it will be resolved soon :).
Reply to Is this condensate pump noise normal? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
