Discuss Is this possible in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone.
I need to install an additional outlet on a heating oil tank it's single walled steel and there's no way to access the inside of the tank. Does there exist any kind of tank fitting that can be used, or do I need another tank?
It hasn't been commissioned yet - it was a custom shape and the customer didn't specify he wanted a dedicated drain outlet. The only outlet on the tank right now is the feed to the boilers - which is 5cm off the bottom of the tank. This will leave about 300 litres of unusable (and un-drainable) fuel - which isn't ideal.
local fab shop to weld a drain / weld olet on the tank?
Reply to Is this possible in the Plumbing Jobs | The Job-board area at PlumbersForums.net
