Discuss Is this Radiator Valve Adjustable? in the Central Heating Forum area at PlumbersForums.net
Hi all, have a radiator in the hallway which has never worked. When I bled the radiators few days ago I checked the hallway one, and it appears to have pressure.
The valve on the right of the radiator is fully open, now the valve on the left I am confused about. It is the type with a small plastic cap on top, and is the only valve of this type in the house. I am unsure whether its an adjustable valve at all. I have tried to open it with pliersin the past but have inadvertedly damaged one of the two top pins holding the plastic cap's screw.
Does anyone know whether this valve is just always fully open, or whether it is adjustable? In which case it could be stuck closed and hence the radiator not working.
Tbh wants replacing now
Also looks shut
Yes it’s adjustable in regards to balancing etc
Chances are it won’t move as it’s probably seized
Reply to Is this Radiator Valve Adjustable? in the Central Heating Forum area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
