Discuss Isolate hot water in unvented pressurised system in the USA area at PlumbersForums.net
I need to turn off hot water in bathroom. There are no isolation valves from unvented indirect pressurised tank in loft. Turning off mains to house stops hot and cold water upstairs, but the hot in kitchen still continues to run (but at reduced pressure). But when I turn mains back on there is a lot of air in system. I thought turning mains off should stop hot as well, but it appears that it will drain hot water tank if I have kitchen tap on. Is this right? The house is three storeys, so alot of head pressure - is this the cause?
My work is on top floor,where the flow stops so seems to be OK, but as I to need to cut into the bath's 22 mm hot supply pipe I'd rather no cockup.
Be very grateful for any advice.
Yes isolate mains going into cylinder, there should be a shut off valve just before or incorporated into the cold water combination valve...
If not just turn off main stopcock as you did.
Hot water will continue to flow until the pressure in the cylinder is reduced, then it will stop - could be a fair bit.
Always a good idea to have a tap open on the floor below where you are working to allow the pipe work to drain fully.
You’ll be fine.
You’ll be fine.
Thanks Ben-gee. Job scheduled for Monday. 🤞🤞
turn the mains water off open cold tap in the kitchen then open one upstairs wait for it to stop close both
open kitchen hot tap and then open a hot tap upstairs will take around 5-10 mins to stop fully
Hi Shaun,
Thanks for that. Will this drain the hot water cylinder?
What should the sequence be when turning water on or doesnt it matter?
Hi Shaun,
no not totally will drain prob around4-6” off the top
no but I would do the cold taps first close to stop tap then upstairs runn until it stops spluttering bath is best then repeat for hot
Brilliantly suggested as apposed to the cylinder being on upper tier of the house would open an upper tap as well as the lowest.👏 and individual if on arrival full on hot water 💧
Reply to Isolate hot water in unvented pressurised system in the USA area at PlumbersForums.net
Hi, Later this year I am going away for a 2 week holiday and as the weather will be warm there is no need for the heating to be on and arguably no need for me to needlessly heat hot water. My intention was to turn the boiler off along with the mains water when going away. Now, I have heard...
