Discuss Jaga radiators - any views in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Anyone any experience of installing, reliability and performance of the Jaga fan assisted radiators
yes I have fitted them used them on a heating system with air source heat pumps worked well and looked the part fans just clip on the underside of the heating coil and plug in they need cleaning regulary as get really dusty but do the job cheers kop.
Reply to Jaga radiators - any views in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Jaga radiators (with heat-exchangers) have their own small fans, that "will modulate down when the room temperature is met – the room temperature is measured by a sensor at the base of the radiator", says Jaga. How does this coordinate with a standard room-thermostat, which of course shuts off...
Free running radiator change. I currently have 1 radiator free running with all of the others fitted with TRV's. Problem is that the free running radiator is in the porch and I'd rather not pay to waste heat there. Question is will it be ok to close this radiator off and ensure that one of the...
Hi all, Looking for some advice please. Got a building, all one level with 7 radiators. 3 individual ones in separate rooms then 4 radiators all together in one large room. The issue is with the 4 radiators in the large room. Basically not getting hot, the first 10% of the radiator is...
Oil boiler (now~15 years old) unvented system with 17 radiators. We moved in 5 years ago and I had to keep bleeding the same radiator. The bleed gas could be burned with a blue flame and the water was acidic (pH 5.5). Since then system has been chemically flushed (it was not too bad) and the...
Hi all. Could someone help with a issue I have been having with my vertical radiator. I have one vertical radiator in my bungalow and it does not heat up unless the surrounding radiators are shut off. I have tried turning the surrounding radiators down but the have to be completely or very...
