Discuss Jammed actuator pins in the Water Underfloor Heating Advice area at PlumbersForums.net
I have some actuator pins that are stuck (in the open position). I assume that the best thing to do is just to replace the entire valve, but is there a quick temporary fix - I.e. lubricating and hitting with a hammer (yes I know it's not the most professional solution)
thanks
Reply to Jammed actuator pins in the Water Underfloor Heating Advice area at PlumbersForums.net
My son has an apprenticeship interview for to become a plumber and heating engineer. The have said there will be a multiple choice exam for this...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
