Discuss Joist not reaching the end in the Ireland area at PlumbersForums.net
We are redoing a wet room on the ground floor and we have uncovered the floor boards.
I'm looking at this and I'm totally baffled.... the joist doesn't even reach the end of the room... what's supporting it is a mystery to me...
What's the best way to fix this?
It's a bit of a disaster...
It's supported by the joist it's attached to which will be supported further down or should be, if you pull another floor board or two you might see it. Main thing is it solid and secure beneath your feet?
Needs what's known as 'triming out ' you need a new section of joist same size as existing fitted between the joist each side to carry the floating end.
You will probably have to take bit ore of damaged joist to get it in. Needs 3 number metal joist hangers to fit it together screwfix sell them Then nail/screw them together .
I think you need to see, it may well be supported just shy of that floor boarding edge. If it's wibbly then you can go to town with joist hangers.
Thank you so much! That's really helpful https://community.NoLinkingToThis/styles/default/xenforo/clear.png I'll get cracking (no pun intended https://community.NoLinkingToThis/styles/default/xenforo/clear.png) https://community.NoLinkingToThis/styles/default/xenforo/clear.png
It's sort of crunch time existing joists don't look great you either spend time/money replacing as needed bracing them up and putting bridging between then, then probably insulation before putting back floor..Remember floor needs to be as much as possible movement free for a wet room.
Or remove joists bring up concrete new dpc membrane decent thickness of Kingspan screed on top ,Could even include proper ufh if budget would stretch no movement solid forever floor up to current regs!
Do you have a plan because you can't really be doing this in a piece meal fashion and then panicking, the wet room floor will need some sloping and a drain point or you're going to be standing in puddles after a shower. This is quite a high level DIY undertaking if you have no experience. I'm not saying you're not capable as we all like a can do attitude, it's just you need to be decide early what you can and can't do and know when to get professional help and this might be that time.
Suzan the timbers look past their best i would honestly employ a carpenter for half a day to replace alot of the joists and brace the floor a wet room needs a good solid base for a succesful outcome heres one i did 2 years ago to give you a idea everything you need is available from the wetroom store one of our sponsors on here . Regards kop
Reply to Joist not reaching the end in the Ireland area at PlumbersForums.net
T
Hi all, seeking advice on my toilet. (Layman here, please be gentle with me.) When we flush the loo upstairs, it flushes fine (therefore assuming...
Hi I am new to this forum so forgive me if I add this to the wrong place. I have purchased a 2 storeys property which will be converted to an...
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
Hi I've recently had a new bathroom installed. I've noticed when I flush the downstairs loo there was a hammer type noise under the bathroom...
Hello, Our bathroom was installed 9 months ago by what we know were tradespeople who did not have the skill or experience to do so. Several...
2K
