Discuss Joule or Telford Vertical Unvented Indirect Cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does any one know how reputable/reliable are Joule and Telford when it comes to their unvented vertical hot water cylinders?
We require a 250l vertical cylinder for our basement and our plumber is used to installing Telford Tempest cylinders but read online that Joule may be a better alternative?
I have 4 Telford tempest unvented cylinders to replace soon all leaking from inside the casing somewhere, just to let you know before you buy.
Joule defo ok , plumb centers own brand ( center brand ) are excellent .
A good tip is a ultrasteel , they are rebadged Tribunes
25 year warranty on the Telford and I presume also on Joule??, so not going to cost you as long as you get them serviced once a year to keep warranty
Joule would be my choice out of the two they do a floating baffel version now which looks impressive , Heatrae Sadias Mega flow patent has ran out so all the top manufacturers have their own versions now best of luck , kop
This is the Joule Evolution . Cheers kop
Personal preference really Chris they both do the same job mate buy mine from Plumbcity all the best kop
Install it proper and they will all do what there supposed to. Its not science. Not derogatory at all but these posts have caused disagreement previously
Reply to Joule or Telford Vertical Unvented Indirect Cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Anyone know of preplumbed horizontal unvented cylinder apart from the Telford Tempest. My plumber has said they save a lot of time but he's fitted gledhill vertical before I think.
Hi, I'm looking to purchase a 300L unvented indirect cylinder to work with a standard heat only boiler. I may have solar panels in the future, but likely the PV kind rather than the thermal kind, and won't be having heat pump in the future. So the cylinder would be connected to the boiler at...
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is unvented and pressurised. The cold water feed into this cylinder is from the attic tank, not the mains as I turned off the mains stopcock to see if hot...
200/210 or 250l indirect unvented cylinder... Pros and cons of both please guys, whats the thinking?? Better to go bigger, or are there other considerations to be thought of....?
6K
T
Hi We urgently need to get our h/w cylinder replaced because it's leaking. Our current system is oil boiler feeding underfloor downstairs, radiators upstairs and an unvented hot water cylinder for hot water. We are thinking of moving to a heat pump at some point but aren't ready to do this. My...
