Discuss junior 24i boilder 4 flashes a second in the Plumbing Jobs | The Job-board area at PlumbersForums.net
junior 24i boilder.
It produces a fault only when running hot water through a tap. The heating works fine every time. The hot water issue is intermittent and producess 4 flashes a seconds fault code.
I replaced the PCB as the pump relay fried last year. The hot water fault was happening before then. But it's starting to bug us now we don't have a electric shower. We only used it to wash the pots before.
We have to reset the boiler a few times before it works. It's perticuallarly bad after the heatings been on.
Any suggestions would be great, just so we know where we are if it needs a technician to look at it. Don't want to get ripped off.
Cheers
Joe
Reply to junior 24i boilder 4 flashes a second in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
My Worcester Combi Boiler is not working, instead the display flashes on and off repeatedly, as shown in <a href=" View...
Just been to a nightmare of a job! Had to carry out a service on the 2009 British Gas 330 + (GC: 41-019-11) It's a Glow Worm boiler. The boiler...
Hi All. As this is quite an old boiler ‐ I'm hoping there are many people familiar with this issue. The boiler works normally for hours (hot...
Hello, recently our boiler stopped working properly, causing a lack of heat in our 14-radiator splitter in 3 storeys. having only one boiler at...
I have a Vaillant ecofit pure, we had it installed about 6 years ago so it's not an old boiler, a new pump was also fitted at the same time...
